Ghost 0.7.8
Ghost 0.7.8 is now available on GitHub, npm and Ghost.org. 0.7.8 is exactly the same as 0.7.7, but with a additional fix for a bug with saving tags.
Highlights
- [Fixed] Unable to add an existing tag to a new post
And from 0.7.7...
- [Fixed] Node v4 LTS support handles 4.3 and all future v4 LTS versions π
- [Fixed] Settings cache cleared on import, so your blog will now look correct without needing a restart
- [Fixed] Various issues with navigation - the UI behaves better, and you'll no longer get ignored by
{{current}}
if you forget a trailing slash. - [Fixed] API serving invalid status codes, which was a potential source of crashes π₯
- [New] The delete all content button now creates a backup file first... just in case π
- And much more...
You can see the full change log for the details of every change included in this release... or read the 0.7.7 change log instead 'cause it is way more interesting π.
How to Upgrade
All Ghost(Pro) users are being automatically updated and will be running Ghost 0.7.8 shortly. You're welcome :)
For people running Ghost on their own servers, you can download Ghost 0.7.8 and then check out the upgrade documentation over on our support site.
Note: Having a correctly configured url in config.js is a hard requirement since 0.7.2. If you get the error Access Denied from url whilst trying to login, please see the configuration documentation.
Enjoy!
Credits
This release was speedily whipped up by Kevin Ansfield.
