Ghost 0.7.4
Ghost 0.7.4 is now available on GitHub, npm and Ghost.org. This contains a handful of bug fixes for things which weren't quite right in 0.7.3, particularly relating to the new Public API features.
Highlights
  • [Fixed] Tag pages for tags starting with numbers
  • [Fixed] Helpers still causing aSyNcId errors when used inside the {{#get}} helper
  • [Fixed] ghost.url.api() utility issue with multiple requests
  • [Fixed] authentication error on resubmitting setup/two
  • [Fixed] broken @last when using {{#foreach}} with limit
  • [Fixed] Duplicate URL input field in image uploader
Also note, in 0.7.3 the ability to use custom post templates was added, but not documented. This is being documented in 0.7.4.
You can see the full change log for the full details of every change included in this release.
How to Upgrade
All Ghost(Pro) users are being automatically updated and will be running Ghost 0.7.4 shortly. You're welcome :)
For people running Ghost on their own servers, you can download Ghost 0.7.4 and then check out the upgrade documentation over on our support site.
Note: Having a correctly configured url in config.js is a hard requirement since 0.7.2. If you get the error Access Denied from url whilst trying to login, please see the configuration documentation.
Enjoy!
Credits
This release was lovingly crafted by Fabian Becker, Hannah Wolfe, Austin Burdine, Kevin P. Kucharczyk and Matt Enlow.
Get notified when we ship new features.
