Home Updates Tutorials Podcast Newsletter Careers ✈️ About Support Back to Ghost.org
/ Releases
Ghost 0.5.5
Ghost 0.5.5 is now available on GitHub, npm and Ghost.org.
Ghost 0.5.5 is a minor update to 0.5.4 which resolves an issue with character encoding for MySQL databases. If you're using MySQL and have upgraded to 0.5.4, please upgrade to 0.5.5. The extra fix can be found here.
Below is the original post about Ghost 0.5.4:
0.5.4 is a maintenance release featuring a very important fix for a memory leak affecting 0.5.3, which causes Ghost to become unstable and crash under heavy load. This update also includes a number of more minor improvements and bug fixes.
Due to the memory leak that has been fixed, this is a recommended upgrade.
Highlights
[New] Postgres is now officially supported
[New] Cmd/Ctrl + s now works on settings page
[Fixed] Memory leak causing instability under load
[Fixed] Autosave triggering 'do you want to leave' alert incorrectly
[Fixed] Issues with uppercase emails
[Fixed] Subdirectory output twice in image URLs
[Fixed] Incorrect twitter card data
As well as many other improvements. You can see the full change log for the full details of every change included in this release.
Credits
This release was lovingly crafted by Jason Williams, Paul Adam Davis, Hannah Wolfe, Matt Enlow, Felix Rieseberg, cobbspur, David Balderston, Robert Jackson, Jilles Soeters, Leonard Camacho, Jacob Gable, Mattias Cibien, Nazar Gargol, Harry Mills, surgesoft, Victor Szeto, Yury Michurin, David Robson, meowtec and John O'Nolan.
Ghost 0.5.5
Share this
