Ghost 0.11.0
Ghost 0.11.0 is now available on GitHub, npm and Ghost.org. This release contains mostly bug fixes, with an important data migration for blogs that didn't have their dates migrated correctly during the 0.9.0 upgrade.
Highlights
- [Fixed] Typing a space in the search bar no longer completes the search π
- [Fixed] Date migrations for sqlite3/postgres blogs that were running in UTC π
- [Fixed] AMP and previews now work properly when running Ghost in a subdirectory.
- [Fixed] Scheduling now works when blogs are run in a subdirectory β°
- [Fixed] Internal tags no longer appear in meta data or RSS feeds.
- [Fixed] More fixes for theme uploads causing unsupported type errors when they shouldn't π
- [Fixed] Uploading over the top of an active theme now correctly reloads the theme & clears the cache π₯
- [Fixed] Issue with
lodash
when Ghost installed as an npm module. - [Fixed] Sitemaps were sometimes rendering without any content π¦
- [Changed] Downgraded missing
{{asset}}
helpers in themes to a warning so they can still be used with caution. - And other things...
You can see the full change log for the details of every change included in this release.
In Detail
This is the penultimate release of Ghost that will work with Node.js v0.10. Please take some time in the next 2 weeks to upgrade. More information can be found in this blog post.
How to Upgrade
All Ghost(Pro) users are being automatically updated and will be running Ghost 0.11.0 shortly. You're welcome :)
For people running Ghost on their own servers, you can download Ghost 0.11.0 and then check out the upgrade documentation over on our support site.
Enjoy!
Note: Due to the dependency changes in the last releases, it may be necessary to remove the node_modules
folder, clear the cache and do a fresh npm install i.e. run rm -rf node_modules && npm cache clear && npm install --production
. This is also described in the upgrade troubleshooting guide.
Credits
This release was lovingly crafted by Hannah Wolfe, Katharina Irrgang, Austin Burdine, Aileen Nowak, Ryan McCarvill, David Wolfe, Sebastian Gierlinger and Kevin Ansfield.
